Help
Solved by Tan3l6,
3 minutes ago, SHADFAN said:So is it okay if I placed the mobo right onto the wood?
I'd still recommend standoffs. Not a good idea to mount on solid wood for a prolonged time imo...
Might be fine, though I can't guarantee anything, I tell the truth on my signature.
Heat would be a problem, if plopped on wood surface tigthly.
