Is my delidded cpu damaged after delidding and would it still work
Solved by WereCatf,
1 minute ago, GougedKirby522 said:--
I'm not an expert at delidding, never bothered with it myself, but the core looks fine to me. The bare copper on the side is kinda worrisome, though. It most likely is just the ground-plane and I doubt there's any traces running so far, close to the edge on the top-layer, so it is probably still fine. Might not be a good idea to have the IHS touching that part directly, though, so maybe cover it with a layer of clear nail-polish or something similar.
