 Hello LTT Fourms, so I just upgraded my computer from a Ryzen 3 1200 on a MSI Z370 gaming plus motherboard. One of the ram slots shorted out and rendered half of my ram usless. But for some reason the ram was still reconizable by my system, but unusable; it was saying it was "Hardware reserved." I looked into the bios, settings, how-to for hours and found nothing to bring it out of being reserved. Frustrated and defeated, I purchased a ryzen 5 3600 with a Asus TUF X570 gaming plus motherboard and 16gb of Gskill 3200mhz ram. I finished building it and more problems compounded the one. For starters, Windows seems to have deactivatd my windows key. I only swapped out the motherboard, ram, and cpu. I kept the storage and powersupply the same. Why would it deacivate? Secondly, Task manager dosent recognize most of the cores or threads of the new cpu. It reconizes that I have a 6 core processor in the title of the cpu, but only reconizes 2 cores and 4 threads in the graph information. Would this be a Bios issue? Finally, half of my ram still says it is reserved for hardware. I do not understand what is going on and any input would be very, very helpful.
https://linustechtips.com/topic/1211210-having-many-computer-troubles-please-help/
You should always just reinstall Windows on a new system.
The product key is tied to the motherboard, so when you swap it out, you will have to purchase Windows again.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
Well yeah, first do the BIOS update, for all parts. Go to the webpage of the manufacturer to see more. I kept the same ROM as well, and took it few hours to recognize the new GPU.
Inform us afterwards
About RAM you use it as dual socket right? I mean right slots?
Windows creates a Hardware ID based on the configuration of the PC. Changing one component like CPU, RAM, GPU, etc is usually fine, but not changing the motherboard. If it is tied to a Microsoft account it is very easy to reactive it.
Try clearing CMOS. You should also do a fresh install of Windows when changing your hardware so drastically.
BabyBlu.2 (Primary):
  • CPU: AMD Ryzen 5 9600X
  • Motherboard: Asus ROG STRIX B650E-F
  • RAM: G.Skill Flare X5 64GB (2x32GB) DDR5-6000 CL30 @ 6400MHz 30-40-40-96
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2100MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 11 Pro
Roxanne (Wife Build):
  • CPU: AMD Ryzen 5 7600
  • Motherboard: Gigabyte B650I AORUS ULTRA
  • RAM: G.Skill Flare X5 32GB (2x16GB) DDR5-6000 @ 6000MHz 30-38-38-96
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Cooler Master MasterBox NR200
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair SF850L
  • Display: Dell Alienware AW3420DW GSync
  • Cooling: Arctic Liquid Freezer II 280mm
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
  • 2.5Gb NIC
  • OS: Windows 10 Pro
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
Yes, It is a dual socket, 8 x 2 kit
windows key is tied to the motherboard. if you bought a retail version you can put in the key or login with your account and it should reactivate it. but if you got the OEM version its technically supposed to be only used for the original computer but you can call them and tell them you are replacing a dead motherboard they will usually reactivate it without asking too much. when i first built my computer i had a fx 6300 and a OEM windows key then i got an i7 4770 with a different motherboard obviously and windows needs reactivation so i used the activate windows by phone call option https://www.microsoft.com/en-us/licensing/existing-customer/activation-centers and i told them i was just replacing a broken motherboard and they asked me for the serial number and activated it LUL
