Hello everyone! I got hooked on LTT at the start of this year through YouTube and this is my first post to the forums :).
I had a question that I needed some tech-savvy help on. So... I recently built my first computer about 6 months ago (that's how I stumbled upon LTT). Since it was my first system, I decided to go with some older (cheaper) hardware. I purchased an Intel Core i7 3770 (non-K... I know...) and an Intel DH77KC mobo (wanted to stick with all Intel). Plopped it into a Phanteks case with some RGB, some Noctua, and I'm happy... life is good...
Now here's the plot twist haha... for my day-job, I'm partially a researcher (I can relate to those LTT videos where the guys are dancing around with lab coats on haha). And I happened to get hooked on Linus' review of the SuperMicro MBD-H11SSL mobo with an EYPC Rome series processor. I couldn't resist LOL... I went with the 32-core 7502P to save some cash though. But now I have two systems... I don't do a lot of graphics-intensive work (my GTX 1060 is fine). I mostly needed lots of CPU cores.
https://www.newegg.com/supermicro-mbd-h11ssl-i502p-ma015-o-single-amd-epyc-7000-series-processor/p/N82E16813183690
QUESTION: are dual ATX cases a "thing"? If so, can someone recommend a decent dual ATX case that could fit both of these systems? I know there are dual cases that support one ATX and one mini-ATX in one package, but I'm going for a full-on Team Purple here haha.
Thanks everyone!
P.S. the next question will be how to get them to talk to each other (since one is a server board)... Ethernet maybe? I'll save that for another post. Gimme all your cases!
https://linustechtips.com/topic/1210922-help-dual-atx-case/
why not just use the epyc as your main pc? it should be faster than the 3770 in basically every task
I don't know of any dual atx cases, Id just get 2 cases next to each other.
How do you want them to talk ? Probalby some sort of IP network. What bandwidth do you need?
https://linustechtips.com/topic/1210922-help-dual-atx-case/#findComment-13730993
I had thought of just swapping over to the epyc... I guess my wallet is still in pain from buying the Intel setup just several months ago haha. I wanted to see if I could still use it in some way. I agree though... if nothing really makes sense, then I'll probably just swap the mobos out and use the Intel board as... a paper weight? a book-end? lol
Very low bandwidth would be needed between them. The simulation software I plan to run just loads a simple ~10 MB file, runs a finite-element analysis (FEA) on it, then sends back the data. The main issue was that I wanted the FEAs to be fast and parallel (hence epyc)... each FEA takes about 5 min to run on a single core of the Core i7 and I could possibly have several thousands of them to run.
Thanks for all the replies so far everyone... that was really quick! haha
https://linustechtips.com/topic/1210922-help-dual-atx-case/#findComment-13731017
wouldn't going full epyc save you money as your could sell the old system? They still go for a good amount.
What os do you use? You can use something like ssh to run it remotly super easily.
https://linustechtips.com/topic/1210922-help-dual-atx-case/#findComment-13731021
