I posted earlier about power supplies and got to talk with someone about CPU's in the thread but I'd like to go more indepth, I'm new to building PC's and im currently putting together a custom PC for my music studio, I'm building a dual boot hackintosh that i'll also ocasionally game from as well too. These are the parts that I have so far, I've got a budget of 1400 but I was wondering is there a cheaper CPU for better money? Most music creation software doesn't deal well with hyper threading and I've got no clue what overclocking does or if it would be good for my situation.
I produce music of all kinds of genres but I also record and mix as well, depending on the genre like EDM for instance the plugins I use are power hungry and tend to use up a lot of CPU power.
Currently i've got an i7 8700 in my parts list but I was wondering if there was a cheaper alternative that's more bang for my buck. I've chosen the motherboard that I have because it has thunderbolt and my studio runs off a thunderbolt system so that can't be changed I'm not sure if that makes a difference or not.
EDIT: My friend is building the computer for me and he's going to take care of the hackintosh side, I'm not doing it myself.
https://linustechtips.com/topic/1210708-cpu-best-for-me/
Just now, emosun said:
You might want to use a real mac if you've never built a pc before as a hackintosh isn't the easiest thing to get working even with the correct parts list especially if you've never built a pc before.
My friend is building the computer for me, he's built hackintosh computers before. I suppose I should put that in the main part of the threat, I'll have to edit it. I can't justify spending that kind of money on a mac anymore, 8 years ago when I bought my laptop I was able to buy in 2020 with their prices and hackintosh computers existing I can't do it.
https://linustechtips.com/topic/1210708-cpu-best-for-me/#findComment-13729080
Also just so you know but hackintosh thunderbolt is one of those barely functional things. If it works at all you will need to restart your pc every time you plug or unplug a device from it.
https://linustechtips.com/topic/1210708-cpu-best-for-me/#findComment-13729093
Just now, jaslion said:
I'd say just get a used mac as well hackintosh for all that it's worth is not an easy to set up thing and unstable as one small update can break everything.
One of my friends is doing the hackintosh part for me, he's done it for years and he said he'd take care of it for me if there's ever an issue
https://linustechtips.com/topic/1210708-cpu-best-for-me/#findComment-13729100
ryzen 7 3700x
https://linustechtips.com/topic/1210708-cpu-best-for-me/#findComment-13729103
This whole system is 2 generations out of date by now and not worth the money. Also why the 2 ssds?
https://linustechtips.com/topic/1210708-cpu-best-for-me/#findComment-13729114
He put it together, We figured having two separate boot drives for each OS would be the best thing to do, he's done it with his dual boot systems before and it works for him.
https://linustechtips.com/topic/1210708-cpu-best-for-me/#findComment-13729123
Can't you just use a Windows only machine? Idk about music software but that seems like the best working thing.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
https://linustechtips.com/topic/1210708-cpu-best-for-me/#findComment-13729134
Makes sense. I also recommend you move to intel 10th gen. The i5's are basically the same as your i7 8700 but a bit better.
https://linustechtips.com/topic/1210708-cpu-best-for-me/#findComment-13729135
Because I do all my recording in logic and it's what im comfortable with, my production is in FL studio and it's better optimised for windows
https://linustechtips.com/topic/1210708-cpu-best-for-me/#findComment-13729153
I'd rather get used to a new recording software than to be locked to MacOS. Is it such a big problem to learn a new software?
https://linustechtips.com/topic/1210708-cpu-best-for-me/#findComment-13729159
I've spent the last maybe 8 years or so using logic and I know it like the back of my hand, finding people that would be willing to come and record while I use new software would be a bigger pain than it's worth. Also it would set back my delivery times, I usually deliver within 5-7 working days but if I have to learn a new software it would hinder that
https://linustechtips.com/topic/1210708-cpu-best-for-me/#findComment-13729165
If that's all you use mac osx for then why not just run it in a vm for logic? Cpu wise if you go for a hackintosh a i5 10400, 10500, 10600, 10600kf or 10600k would do. If going the vm route a ryzen 3600.
https://linustechtips.com/topic/1210708-cpu-best-for-me/#findComment-13729170
Hey I also have an idea here. Why not just get a cheap mac mini for logic and then a windows pc for the remainder? As you need to reboot to get into the other os anyways this way can very well work.
https://linustechtips.com/topic/1210708-cpu-best-for-me/#findComment-13729175
It's just a lot simpler for me if I go the hackintosh route, not having two computers and constantly having to switch over HDMI chords and whatnot to connect to my monitor, I'll be able to share audio files between the "two computers" easer than if I have two actual computers, I've worked out of my friends studio and I enjoy the workflow between the two.
https://linustechtips.com/topic/1210708-cpu-best-for-me/#findComment-13729209
Ok then take the suggestion of the cpu's I listed. Preferably grab a k series one so you can oc in the future. Do keep in mind you need a 400 series motherboard then.
https://linustechtips.com/topic/1210708-cpu-best-for-me/#findComment-13729216
https://linustechtips.com/topic/1210708-cpu-best-for-me/#findComment-13729221
