code Need help setting up Java comparison
By
SavageNeo
in Programming
in Programming
Solved by Mateyyy,
I've not personally worked with Java so for all I know I could be wrong, but isn't "luku == 0-49" incorrect in this context?
For example if you change "if (luku == 0-49)" to "if (luku >= 0 && luku <= 49)", does it work as intended?
Ryanwake ·
Posted in General Discussion1 -
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases0 -
2
thrasher_565 ·
Posted in Hot Deals0 -
5
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
10
derekchan ·
Posted in New Builds and Planning16
play_circle_filled
Latest From ShortCircuit:
