I am looking for an external 2tb hard drive that uses usb 3.0 to replace an old 1TB WD hard drive because it uses usb 2.0 and I am worried about it failing. currently I am thinking about getting a 2tb Seagate Backup Plus Slim but I want to get advice on reliable external hard drives, which drives or backup solutions do you guys use?
I am also thinking about getting a synology nas, any advice?
There all basically the same, Id get what is cheapest.
Get multiple if you need reliable, any drive can fail at any time.
If its just for one systems backup a nas is probably overkill, but not a bad solution for file storage.
Alright, I am probably going to get the drive.
I might get the nas later but the idea is to do backups and store other files and maybe run a few docker containers
I've always had excellent luck with WD stuff.
Do you take it around with you, or does it sit on a desk?
The Porsche Design stuff is quite nice, and can be had quite cheap on eBay. I have one of those as well, and intend to get 2 to replace it when I do a system update later this year. Or perhaps some GDrives.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
1 minute ago, mtz_federico said:
it sits on a desk
Then I'd get something that's not meant to be portable. You'll get more power to the drive and the connections are usually a lot more solid.
like an internal hard drive and an enclosure or an external tower hard drive?
You can get external HDDs that use 3.5" drives and better connections. For example I have a Porsche Design P'9231.
I suggest you get a drive + cloud storage. Do not make it a single point of failure storing all data (backups) in one place. https://www.vmwareblog.org/3-2-1-backup-rule-data-will-always-survive/. E.g., Backblaze personal backup costs $6 per month https://www.backblaze.com/cloud-backup.html
For instance, to add redundancy you can get a cheap 2-bay HDD enclosure and make it RAID 1. https://www.amazon.com/usb-raid-enclosure/s?k=usb+raid+enclosure&page=3
