Is there a significant temperature gap between mesh and non mesh cases?
Guest
usually yes
Phone: Pixel 3a (Purple-ish).
Build Log:
1 minute ago, TofuHaroto said:
usually yes
Around 5 degrees?
Just now, Berkomeister said:
Around 5 degrees?
It's going to depend a lot on the specific case. Not all mesh cases are created equal, and not all non-mesh cases are created equal.
Do you have specific cases you're looking at?
Around 5 degrees?
usually  more
check this video bitwit made
Build Log:
Meshify C and Define R6
meshify only torture cpu
gpu only 2x meshify
The Meshify C is good when you add a couple of fans to the front and will outclass the Define C (or R6/ 7) by almost 10ºC at worst case scenario (assuming your build is exactly the same).
Same thing with the Meshify S2, though it comes with 2 front fans by default so it's less important to buy additional fans.
fractal s2 meshify cpu only
fractal s2 meshify gpu only
@TVwazhere Think the meshify c is also smaller. Thanks for the detailed response
Correct. The Main difference between the R/S series and the C series is size. C is for compact; it's approximate 4" (100mm) shorter than the R or S series.
