no display output
Go to solution Solved by Edgar R. Zakarian,
3 hours ago, AkaTheUnknown said:
using windows 11 23h2
Guess either dead PCI slots or dead GPU then.
More likely the GPU.
Any chances of borrowing another GPU for testing or testing the card in another guys PC?
my current system is a intel i7 3770k with 16gb dd3 ram (power supply is a VS450)
I tried installing an Msi gtx 560 ti (msi n560gtx-ti-m2d1gd5/oc)
without the gpu installed it works perfectly
but with the gpu installed it wont post, with both onboard and dedicated slots
tried both pcie slots on my motherboard ( msi z77ma-G45) but it still doesnt work
https://linustechtips.com/topic/1572403-no-display-output/
24 minutes ago, Blasty Blosty said:
Have you tried the GPU in a different pc? It may be faulty and causing it not to post.
You could also try resetting the CMOS by taking the battery out for a minute or two then putting it back in
I dont have a different pc to try it on
but no i havent tried resetting the CMOS, ill try it now and will let you know if it works or not
https://linustechtips.com/topic/1572403-no-display-output/#findComment-16427771
Try updating the Bios https://www.msi.com/Motherboard/Z77MAG45/support
If that fails, try Clearing the CMOS by removing CMOS battery and shorting the CLR_CMOS jumper pin on the motherboard
Please click the "Thumbs Up" on any volunteer's post to thank them if they helped .(lower left, just to the right of My Computer )
https://linustechtips.com/topic/1572403-no-display-output/#findComment-16427860
3 hours ago, Blasty Blosty said:
Well with the info provided I would assume it is a GPU issue
Can you recall any events that may have damaged it?
no i cant
but the gpu is a pretty old one, my dad found it while clearing the shed (has been there for about 6 years±
https://linustechtips.com/topic/1572403-no-display-output/#findComment-16428012
11 minutes ago, AkaTheUnknown said:
no i cant
Hmm it is likely just corroded or otherwise damaged if it has been there that long
Console.WriteLine("Hello World!");
https://linustechtips.com/topic/1572403-no-display-output/#findComment-16428030
i have done both but it still wont work
https://linustechtips.com/topic/1572403-no-display-output/#findComment-16428052
10 minutes ago, AkaTheUnknown said:
aah ok thanks
You could try disassembling, cleaning, and reassembling? At this point I would argue there is not much to lose, it doesn't work now but it might just need a clean.
https://linustechtips.com/topic/1572403-no-display-output/#findComment-16428991
  • 4 weeks later...
didnt work, and but i decided to take another look at it and then i saw there are spots where it looks like theres supposed to be capacitors (dont know if it was missing first time and i just didnt notice)
i circled the spots where it appears to be missing caps
i know where i can get caps and know where i can get them soldered, so if anyone knows if there is supposed to be caps there please let me know
https://linustechtips.com/topic/1572403-no-display-output/#findComment-16456438
Sometimes there are spots left like that for higher end models that use the same board, unless there is residue of a previous apparent capacitor I would say that looks normal
https://linustechtips.com/topic/1572403-no-display-output/#findComment-16456476
Are you running a completely updated windows? Which version?
I experienced once, where an older gen PC wouldn't post with a GTX 1060.
After updating windows it started working again.
I know it sounds weird, but I remember finding some forum posts to support the reason why.
However, it does unfortunately sound like a dead GPU 😞 So as others suggested, fastest way would be if you know somebody who has a working PC, and plug that GPU into their system and see if it works.
AMD Ryzen R9 5900X  | Arctic Liquid Freezer II 360  |  GIGABYTE X570S AERO G  |  2x32GB G'skill TridentZ 4000MHz  | MSI RX 6900 XT Gaming Z Trio 16GB Dark Base Pro 900 (Orange)  | TOSHIBA 4TB 3.5" Drive - Game Drive | KINGSTON SNVS1000G 1TB M.2 NVME SSD - Boot Drive | FSP Hydro PTM PRO 1000W |
Living Room PC: AMD Ryzen 2400G | MSI RX VEGA 56 8GB AERO | 2x8 GB Crucial Ballistix 2400MHz | Intenso 250GB SSD | Seagate 500 GB HDD | Node 202 + 850W PSU |
https://linustechtips.com/topic/1572403-no-display-output/#findComment-16456516
No POST when the card is installed even when you connected your display to iGPU is a sign of card causing pci device initialization problems. Its probably dead.
https://linustechtips.com/topic/1572403-no-display-output/#findComment-16456522
https://linustechtips.com/topic/1572403-no-display-output/#findComment-16457272
https://linustechtips.com/topic/1572403-no-display-output/#findComment-16457404
most likely dead gpu, because ive been using integrated graphics since i got this pc and i havent used any of the pcie slots before
https://linustechtips.com/topic/1572403-no-display-output/#findComment-16461235
