1 minute ago, Goku1814 said:
Where is the power on off & reset on the MSI B450 Gaming Plus
There's this thing called "a manual" that came with your mobo; I recommend finding this "manual" and opening it up. If you have lost this magical thing, you can obtain a new copy from the manufacturer's website as well!
https://linustechtips.com/topic/1207072-cant-power-on/#findComment-13699840
I had that plugged in didn't work and everything is probably plugged in
What happens if you short the two power pins with a screw driver? Does it turn on then?
If yes, then either the power button isn't properly connected or doesn't function.
https://linustechtips.com/topic/1207072-cant-power-on/#findComment-13699860
Still not powering on ugh. I've changed to my old power supply for my old computer and got a proper power on button and still nothing. I'm hoping my mobo isnr dead bc i just got yesterday
https://linustechtips.com/topic/1207072-cant-power-on/#findComment-13699956
