Ok, so a company I am working for decided to upgrade a server of theirs, and now they are having some issues getting things to work together.
System specs are
Ryzen 9 3950x
64gb 3000mhz ram
Asus prime X570-p
5x 4tb wd red has drives
1x sad for FreeNAS
4x 2tb nvme drives on an expansion card
Issue one...
They had a 3200g in the system before, and the new cpu doesnt have integrated graphics.
So we are trying to run headless...however everything I have tried, the system still hangs on VGA check on the Q-led display
Issue 2
ASUS Hyper m.2 card is only detecting 1 drive in pcie x16 slot 2, and detecting NO drives while in pcie x16 slot 1.
However all 4 led lights are green on the back of the card.
Not sure if I need to set It to raid mode without actually setting raids as i want FreeNAS to handle it..
Any help would be appreciated as I'm currently banging my head against my keyboard while I'm trying to do this remotely...
https://linustechtips.com/topic/1206545-freenas-system-troubleshooting/
So do you have a discreet gpu installed? With no iGPU there will be no video. I can only think of maybe the bios isn't set right for the pcie issue, I'm not sure.
Newbie here
2 and a half years in this field
Take my advice with a grain of salt!
Does it support pcie bifurcation? You need pcie bifurcation for those cards to work.
Some boards like yours just won't support it. Id get a board with a igpu like the asrock rack ones, or get a cheap gpu for the system like a gt 710.
Some boards won't boot without a GPU of some sort installed. At current I don't know of any dummy-plug way around it.
If this is a server being used in a server application why has server hardware not been used?
Yes, according to ASUS it does, seems after some digging however it only supports a total of 2 NVME Drives via the card tho....
in theory could i get another expansion card and use PCIE_1 and 2 to get 3 NVME drives and then use the on board NVME slot to make it to 4 or is that not how that would work?
you may need to enable it in the bios, check with the board manual.
Yea, you should be able to do this, but id probably just get a single faster ssd if it was me.
Also how are you using the cache drive in freenas? IM guessing it won't help that much, slog is only used for sync writes and l2arc probably won't help here.
actually the 5 satas are their own thing, the ssd is for the OS and the nvme's will be for something completely different still.
customer wants to retire their old webserver and put it on this....so it will be running several different things....
also im just the hardware guy XD
Id stay away from freens then, and get. os tht much better t running vms, like proxmox on the hardware then.
Also if you can return it, id really try to get some real server parts like the asrock server board or a refurb dual xeon system.
