CPU stuck at max frequency.
Solved by Pachuca,
4 hours ago, Light034 said:It's already on balanced.
It's possible the bios update changed some of your default settings. I don't remember the exact setting, but there is a bios option that basically makes the cpu run at full even if it's idle. It has to do with intel's P-state and C-state settings. You'll have to search through the bios to find it and change it.
Featured Topics
LucasTSP ·
Posted in General Discussion1 -
madsci1016 ·
Posted in General Discussion0 -
Jimmie22 ·
Posted in Troubleshooting9 -
SnowYetti ·
Posted in Cases and Mods1 -
4
2
6
svvkjbe ·
Posted in Graphics Cards7 -
TheDarkLoS ·
Posted in New Builds and Planning5
