75 in an artificial test like cinebench is good
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1205654-cpu-temperature/#findComment-13687502
It's good ;)
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1205654-cpu-temperature/#findComment-13687504
2 minutes ago, coneil3822 said:
Hello I have just finished my PC build. I get 60-65c in Warzone and 75c in Cinebench. My CPU is a 3800x and I have an AiO. Is this good? Sorry just need some reassurance as this is my first build. Thank you.
The max allowed temp with that CPU is 95C, so you're in safe territory in general.
There are many different AIOs (with many fans, few, different sizes, etc.), but I would generally say 65-75C max is good, if you are working with a 20-30C ambient temp.
https://linustechtips.com/topic/1205654-cpu-temperature/#findComment-13687508
