Android phone for pc case temp display (HELP)
Go to solution Solved by BlueChinchillaEatingDorito,
17 minutes ago, GetShmokdByWill said:
Hey,
so here’s the run down, I want a old android phone to display my pc stats using this app I found, the phone will sit in my case on a charger and stay in case.
Problem:
everytime I turn the pc on or off I would like the phone to turn in and off so the phone doesn’t explode and sit on for weeks on weeks.
if I can get the problem above solved I will need a way to open the pc stats automatically when the phone turns on without entering the case to click the app,
idk if this is possible but this would be a great project and I need some android users help as I am a Apple user myself 😞
gl everyone in your findings hopefully I can get some answers!
I'm not an Android wizard myself, but I think adb (Android Debug Bridge) is something that might help you achieve what you're looking for.
Turning off Android device remotely using adb:
https://android.stackexchange.com/questions/47989/how-can-i-shutdown-my-android-phone-using-an-adb-command
Open apps remotely using adb:
https://stackoverflow.com/questions/4567904/how-to-start-an-application-using-android-adb-tools
I would imagine you can you have these commands entered via a script that triggers when your computer boots up and shuts down.
As for turning the phone on, you can try removing the battery and seeing while plugged into the USB port of your computer, if it boots up the moment you turn on the computer and power is running through the USB port.
Hey,
Problem:
https://linustechtips.com/topic/1204692-android-phone-for-pc-case-temp-display-help/
Hey,
Problem:
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
Very helpful, I will order the used phone tonight and give an update if I need help or if any problems occur
