ssd help
Go to solution Solved by Jurrunio,
1 minute ago, TeaAitchSea420 said:
whats the 6gb/s in reference to?
SATA 3. There's SATA 2 (3gbps) and SATA (1.5gbps) but they are backwards compatible (so SATA 2 SSD on SATA 3 slot runs SATA 2 speeds)
Hi
hi
https://linustechtips.com/topic/1204607-ssd-help/#findComment-13679001
6 minutes ago, TeaAitchSea420 said:
it definetly supports sata m.2?
Desktop benching:
https://linustechtips.com/topic/1204607-ssd-help/#findComment-13679024
The max Speed of sata3 devices. Usually sata SSDs are almost that fast
Hi
hi
https://linustechtips.com/topic/1204607-ssd-help/#findComment-13679032
Desktop benching:
https://linustechtips.com/topic/1204607-ssd-help/#findComment-13679034
-= Topic moved to Storage Devices =-
 CHRISTIAN MEMBER
https://linustechtips.com/topic/1204607-ssd-help/#findComment-13679069
