21 minutes ago, PurplDrank said:
Like aviators? Or like a wayfarer like an oakley holbrook?
imo they look good
im not into sun glasses but i do like metal frames and roundish glasses ( but that is just my preference)
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1204566-need-sunglasses-advice/#findComment-13678749
4 hours ago, TofuHaroto said:
imo they look good
I tried on a dif pair of the same model just with lighter colored lenses and it made it look smaller
https://linustechtips.com/topic/1204566-need-sunglasses-advice/#findComment-13679771
huh weird
i never wear sun glasses as im almost legally blind without glasses so thats kind of a bummer
Build Log:
https://linustechtips.com/topic/1204566-need-sunglasses-advice/#findComment-13679775
Can just buy dif lenses
are there lenses for glasses that act like sun glasses ?
Build Log:
https://linustechtips.com/topic/1204566-need-sunglasses-advice/#findComment-13679789
1 minute ago, PurplDrank said:
You mean frames that you can have both prescription lenses and sunglass lenses and just switch em out ?
i guess ? i dont really know lol
Build Log:
https://linustechtips.com/topic/1204566-need-sunglasses-advice/#findComment-13679797
Go to oakley and look, im sure there are. Alot of the oakley sunglasses have interchangable lenses that you can switch out
ill check it out ;)
cheers
Build Log:
https://linustechtips.com/topic/1204566-need-sunglasses-advice/#findComment-13679819
Yeah, i have polarized ones and they are pretty epic. You can just go to your local glasses shop and ask them for sunglasses.
There are also transitions, glasses that automatically go from normal to sunglasses.
I only see your reply if you @ me.
https://linustechtips.com/topic/1204566-need-sunglasses-advice/#findComment-13687689
Wow 🤨 Glasses surely have gotten better
I mean right now I don't need it and it will probably be for later
Maybe something I can save up for as decent quality lenses tend to be expensive
But I'll check it out
Now I have to go to sleep because it's 1 am 😂
Build Log:
https://linustechtips.com/topic/1204566-need-sunglasses-advice/#findComment-13687705
