FX 9590 Underclocked... for now ##HELP?##
Hi guys, so I wanted to know if I was to buy an FX 9590 and just under clock it to 8350 ish levels would it still have that ridiculous 220W TDP or would the TDP be the same as the FX 8350s TDP of 125W.
I have an opportunity to snag one of these for $320 right now which is way better than the original $750 price tag from 8 months back. My goal ultimately is to have this thing at its stock speeds or higher but I need to get a far more robust cooling solution before I can even think about that.
So essentially my question is, will this thing run as cool as an FX 8350 if clocked down the 8350 speeds or is it naturally a hotter running chip? Any feedback from an FX 9590 owner would be greatly appreciated and of course any body else can chime in as well.
Thanks!!
It would run cooler and use less power due to the superior binning, the 9590 is essentially a super efficient 8350 that overclocks like a beast.
