Hi everyone
I have a bit of a predicament and needed some assistants please. So basically i have a laptop, and somewhat old monitor. The monitor only consist of cable for sound and power. and a VGA cable. I brought an adapter for the VGA cable which allows a USBC on the other end. So i can plug my VGA cable into my adapter, then plugging my adapter (USBC) into my laptop. Know, whatever my laptop displays is also shown on the monitor. However I want two screens doing two different things, for instance if i have a tab open on my laptop it'll show on the monitor also. But i want that tab to stay open on the monitor while i have a different tab open up on my laptop. I know they're connected but is there a way where i can have two different tabs or videos open without the screen changing even though they're Both interlinked?
https://linustechtips.com/topic/1203255-can-anyone-help/
In display settings see if it is set up in mirrored or extended. Mirrored is where it shows the same thing on both displays, so you'll want it on extended.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1203255-can-anyone-help/#findComment-13668101
Windows+P.
That's the shortcut for the screen settings you're looking for. Set it to 'extend'.
https://linustechtips.com/topic/1203255-can-anyone-help/#findComment-13668121
