Hello everyone..
I’ve just put together my new PC and have powered on for the first time. The power all comes on, all fans etc are running and no warning LED’s.
i would expect to see an MSI boot screen but I’m currently just getting a black screen
My spec is..
i9 9900K
MSI Z390 Gaming Pro Carbon AC
32GB Corsair Vengeance 3200 RGB
MSI GeForce RTX 2080 Super
1TB Sabrent Rocket NVMe
750w Corsair PSU
Corsair H60 CPU Cooler
This is the first build I’ve done.. ever. I look to have everything connected, not sure where to go now. There’s 1 socket on my motherboard ‘CPU_PWR2’ which is currently not connected, could this be the issue?
Thanks!
Dan
https://linustechtips.com/topic/1202319-i9-build-help-required/
Assuming the "CPU_PWR2" is the secondary 4-pin EPS connector on the board, no, you don't need that.
Have you checked the Debug LEDs on your board? Is the video cable plugged into the graphics card? Is the monitor turned on and have you selected the correct input in its settings (HDMI, Displayport, etc)?
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1202319-i9-build-help-required/#findComment-13660548
Just now, Danm90 said:
Thanks for the fast response guys.
I’ve tried both HDMI’s, 1 on the motherboard and 1 from the GPU. None of the debug LED’s are currently lit up. Yeah the monitor is on and I’ve selected the correct input.
Did you try taking the gpu out and just using the onboard graphics?
Try unpluggin everything thats not needed.
https://linustechtips.com/topic/1202319-i9-build-help-required/#findComment-13660562
Can you try 1 ram stick at a time ?
Please quote or tag me @Void Master,so i can see your reply.
Everyone was a noob at the beginning, don't be discouraged by toxic trolls even if u lose 15 times in a row. Keep training and pushing yourself further and further, so u can show those sorry lots how it's done !
Be a supportive player, and make sure to reflect a good image of the game community you are a part of.
Don't kick a player unless they willingly want to ruin your experience.
We are the gamer community, we should take care of each other !
https://linustechtips.com/topic/1202319-i9-build-help-required/#findComment-13660567
I'd try checking whether the CPU is seated properly (maybe actually reseat it while you're at it), and recheck all the power connectors to make sure they're all plugged in all the way.
https://linustechtips.com/topic/1202319-i9-build-help-required/#findComment-13660588
10 minutes ago, Danm90 said:
I’ve just taken the GPU out and I’ve managed to get to the boot menu, thanks a lot!
My main concern is if I plug it back in once Windows is installed, will I have the same issue?
Really appreciate the help everyone.
Probably the GPU is faulty....
Are the GPU power connectors plugged it correctly ?
If yes then u should RMA the card....
https://linustechtips.com/topic/1202319-i9-build-help-required/#findComment-13660624
Good to hear it's not something more major.
Try reseating the graphics card, checking the power connections on both ends for it, and seeing if that does the trick. I've had a similar problem where I wouldn't get any display output to the monitor, but reseating the graphics card actually fixed it. If that doesn't work, try a different slot on the motherboard.
Also, please use quotes or tags so we can be notified whenever you reply.
https://linustechtips.com/topic/1202319-i9-build-help-required/#findComment-13660647
Thought I’d quoted your reply 😂
https://linustechtips.com/topic/1202319-i9-build-help-required/#findComment-13665001
