Water cooling vs. Air cooling..
sydneyc
 Share
Hello! I'm planning around building a PC rig with a Ryzen 3950x CPU and 2080ti GPU, I may be overclocking, I haven't decided yet. I'm cross between what type of cooling I should have. I've watched videos, but still don't know what I should do. This rig is already costing a lot but it is completely worth it, lmao. I know what coolers I'm thinking about getting.
For water, NZXT Kraken Z63 with LCD display.  $250
For air, DEEPCOOL GAMMAX GTE V2. $30-$40ish
Yes I see the price difference! lmao. Both allow for basic overclocking, but of course the water (I think) can allow more. I'm truly split, I've also never had a water cooled system so I'm kinda worried about it. Also with money. Thank you! :)
Edited by sydneyc
1 minute ago, 6x6 said:
Is this you shorturl.at/ahxzD
Just now, sydneyc said:
He likes your rig and figures you be like.....
7 minutes ago, sydneyc said:
For water, NZXT Kraken Z63 with LCD display. $30-$40ish
You mind telling us where you found a Kraken Z63 for $30-40ish? I might need to get 1... or 20.
For air, DEEPCOOL GAMMAX GTE V2. $250
You mean that but flipped? $250 for a air cooler is ridiculous. $40 for a 240mm watercooler is bu||$h!t. You should probably get a Dark Rock pro 4 or Noctua dh-15 CHROMAX if you want to oc, or just for normal operation. All liquid coolers are underperforming for price, and are basically equivanlent to an air cooler 1/2 of the price- But the 360mm+ air coolers do slightly outperform any air cooler, not mentioning they look pretty sick. Honestly get an air cooler unless you really don't mind spending a lot of unwarrented extra money for slightly better performance and good looks. By the way, can you post your build here so we can help you revise if there's something wrong?
I am NOT a professional and a lot of the time what I'm saying is based on limited knowledge and experience. I'm going to be incorrect at times.
Motherboard Tier List                   How many watts do I need?
Best B550 Motherboards             Best Intel Z490 Motherboards
PC Troubleshooting                      You don't need a big PSU
PSU Tier List                                Common pc building mistakes
PC BUILD Guide! (POV)              How to Overclock your CPU
I think he got it flipped, otherwise I'ma head out and buy whatever company is selling this out of stock.
Oh, I flipped it.
12 minutes ago, The_russian said:
(One of us is bad at jokes. It's me) In your case:
R/ wooooosh
 Share
