Laptop Display not allowing 144htz
Mr_MagicMan
Picked up this laptop that has a 144htz display, odd thing is I can't get it to run at 144, its a clevo P65xRP6 with the 1080p 1060m 8gb ddr4 2400 and the optional fingerprint scanner. The laptop display is 144htz, I have done numerous driver reinstalls and even grabbed the old drivers from the website but i cannot get it to run at 144, my only options are 60 and 48. I know this is a 144htz display since there is only one model, the 144htz. There is literally no option for it I am stuck and have to come here again.
I swear to god don't even tell me to go to advanced display properties or the nvidia control panel and make a custom res.
Yes, I disabled nvidia optimus, I have it to only run on the 1060 and I still cant.
any knowledge or help would be appreciated.
image0.thumb.jpg.64a9b5befaee406e6b23dd379414cf11.jpgimage1.thumb.jpg.8402c420f91e0630e1e4863a386dfad4.jpg
sorry for them being so big, its terrible right now
4 minutes ago, Mr_MagicMan said:
I just realized this is in the wrong section
fixed ;)
If you need help with your forum account, please use the Forum Support form !
Go into your Nvidia control panel and set your resolution there.
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
Ive, already tried that...
Oh! My bad, I thought the bottom photo was windows settings not Nvidia. What model is your lappy? Are you sure it's 144hz?
Gaming Build:
Peripherals:
Laptop:
NAS:
QNAP TS-451
6TB Ironwolf Pro
Are you able to find out what the panel brand + model is?
I'm looking online, and if yours has the 1920x1080 IPS LG Philips LP156WF6 (LGD046F) panel, it is 60 Hz.
Intel Z390 Rig ( *NEW* Primary )
Intel X99 Rig (Officially Decommissioned, Dead CPU returned to Intel)
  • i7-8086K @ 5.1 GHz
  • Gigabyte Z390 Aorus Master
  • Sapphire NITRO+ RX 6800 XT S.E + EKwb Quantum Vector Full Cover Waterblock
  • 32GB G.Skill TridentZ DDR4-3000 CL14 @ DDR-3400 custom CL15 timings
  • SanDisk 480 GB SSD + 1TB Samsung 860 EVO +  500GB Samsung 980 + 1TB WD SN750
  • EVGA SuperNOVA 850W P2 + Red/White CableMod Cables
  • Lian-Li O11 Dynamic EVO XL
  • Ekwb Custom loop + 2x EKwb Quantum Surface P360M Radiators
  • Logitech G502 Proteus Spectrum + Corsair K70 (Red LED, anodized black, Cheery MX Browns)
AMD Ryzen Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
Intel Z97 Rig (Decomissioned)
  • Intel i5-4690K 4.8 GHz
  • ASUS ROG Maximus VII Hero Z97
  • Sapphire Vapor-X HD 7950 EVGA GTX 1070 SC Black Edition ACX 3.0
  • 20 GB (8GB X 2 + 4GB X 1) Corsair Vengeance DDR3 1600 MHz
  • Corsair A50 air cooler  NZXT X61
  • Crucial MX500 1TB SSD + SanDisk Ultra II 240GB SSD + WD Caviar Black 1TB HDD + Kingston V300 120GB SSD [non-gimped version]
  • Antec New TruePower 550W EVGA G2 650W + White CableMod cables
  • Cooler Master HAF 912 White NZXT S340 Elite w/ white LED stips
AMD 990FX Rig (Decommissioned)
  • FX-8350 @ 4.8 / 4.9 GHz (given up on the 5.0 / 5.1 GHz attempt)
  • ASUS ROG Crosshair V Formula 990FX
  • 12 GB (4 GB X 3) G.Skill RipJawsX DDR3 @ 1866 MHz
  • Sapphire Vapor-X HD 7970 + Sapphire Dual-X HD 7970 in Crossfire  Sapphire NITRO R9-Fury in Crossfire *NONE*
  • Thermaltake Frio w/ Cooler Master JetFlo's in push-pull
  • Samsung 850 EVO 500GB SSD + Kingston V300 120GB SSD + WD Caviar Black 1TB HDD
  • Corsair TX850 (ver.1)
  • Cooler Master HAF 932
I did buy this laptop second hand, seller claimed it was 144htz, and it was running at 144htz when I took a look at it when I was going to go buy it, It indeed was running at 60, but he did show me the 144htz option that was actually available. Also said that it was an upgraded pannel to the 144. Custom built too.
At this point do you think I should reinstall windows, or contact the seller again to get an actual confirm it is 144?
When I recieved the laptop and got home the first thing I did do was update the gpu drivers and reset the laptop entirely, removing all programs and everything off of it. I also did the may 2020 update aswell so could that have broke and caused something to happen?
The model: the Clevo P65xRP6 the rp in it I guess is hinting to that LG phillips display. It is also a gsync display too is that matches up with that LPWF6.
