how many fans and where
Solved by Fasauceome,
7 minutes ago, wassil said:is ok do get a cheap case and put 3 fans ? what are the risks or the downsides ?
cheap isn't really important, unless you care about build quality and good materials. What you want is airflow, get as cheap a case as you want as long as it can breathe.
example of a cheap case that is good:
https://pcpartpicker.com/product/vYp323/cougar-mx330-atx-mid-tower-case-mx330
