I bought a new gpu, upgrading from a gtx 1050Ti to a gtx 1660super. After running some games to see how it's performing, I noticed a huge differance, playing with low settings at barely 60 fps with old gpu to high settings, 100+fps with the new gpu. Now, in Gta V is a total downgrade.I mean i barely get 50 fps in the town with low textures and shading and mostly everything else from the old 1050Ti that i could reach smooth 70 fps with high textures and high shading... What is happening? Can someone explain why only in GTA V i get worse frames than before????Also, the game is installed on hdd but that doesnt matter cause when i had the old gpu it was running smoothly...Help please?
https://linustechtips.com/topic/1200176-gta-v-low-fps/
Did you get the 1660 super drivers?
Quote me for a reply, React if I was helpful, informative, or funny
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
https://linustechtips.com/topic/1200176-gta-v-low-fps/#findComment-13644880
Just now, Rafael F1 said:
What is DDU? I installed the new ones from nividia site
DDU is display driver uninstaller. Install the program, run it and then re-install the drivers from the nvidia website:
https://www.guru3d.com/files-details/display-driver-uninstaller-download.html
https://linustechtips.com/topic/1200176-gta-v-low-fps/#findComment-13644895
And also, the gpu was not NVIDIA GTX 1660 Super but a Geforce one, and it came with Aorus drivers CD
They're the same thing...
And ddu is this thing that full erases a gpu driver
AMD blackout rig
https://linustechtips.com/topic/1200176-gta-v-low-fps/#findComment-13644899
So, I have the nivida drivers, should i install the aorus ones ?
https://linustechtips.com/topic/1200176-gta-v-low-fps/#findComment-13644904
