Hey guys, I am planning on building a living room PC and I know how much power my parts are going to use and they shouldn't exceed 400W even at max load, so I don't really need a beefy power supply.
Is the Cooler Master MWE White 500V2 worth a look?
£37.99 or $46.80 (approx.) so it's quite affordable but is it any good?
I've been doing a little research and i've had a Cooler Master B700 back in the day which served me well for 6 years and this MWE PSU delivers most of it's power on the 12v rail which is what's generally accepted as being decent?
https://www.scan.co.uk/products/500w-cooler-master-mwe-500-white-v2-230v-fully-wired-80-plus-single-rail-41a-1x120mm-fan-atx-psu
| CPU - AMD Ryzen 7 5800X | RAM - Patriot Viper 32GB DDR4 CL 16 3200MHz RGB RAM | GPU - AMD Radeon RX 6700 XT 12GB | Motherboard - MSI MAG B550 Tomahawk |
| PSU - Gigabyte Aorus AP850GM | Case - NZXT H510 Flow | YouTube - SgtKenzo |
https://linustechtips.com/topic/1200116-cooler-master-psus/
you can take a look at the PSU tier list here
would recommend you something better though, do you have a budget?
G502 Lightspeed Review
PC:
i5-6400
GIGABYTE GA-H110M-DS2
CORSAIR VENGEANCE LPX 2X4 DDR4-2666MHz
ASUS ROG STRIX-GTX 1060-O6G
SEAGATE 2TB HDD
FUJISTU F300 240GB SSD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Logitech G310 Atlas Dawn (Romer G)
Rexus Legionare MX5.1 (Content Browns)
Mice:
Logitech G602
Logitech G502 Lightspeed
Steelseries Rival 105
Logitech M330
Headset:
Logitech G430
Cooler Master MH 752
https://linustechtips.com/topic/1200116-cooler-master-psus/#findComment-13644413
the B700 is not a good powersupply btw,
that is not a indication that its decent.
current stock of MWE white V2 units should be avoided.
you can get the system power 9 instead
https://uk.pcpartpicker.com/product/b37v6h/be-quiet-system-power-9-500-w-80-bronze-certified-atx-power-supply-bn246
for less iirc.
https://linustechtips.com/topic/1200116-cooler-master-psus/#findComment-13644617
5 hours ago, 5x5 said:
The MWE white models are horrible. Avoid them. Get a Corsair CX550 or SeaSonic S12III 500W
Eh, MWE V2 White not 'horrible', it has problems with low load ripple that's why it's low on the tier list, but for 40 pounds ? I'd say it worth it if used in relatively low-end PC.
Tag or quote me so i see your reply
https://linustechtips.com/topic/1200116-cooler-master-psus/#findComment-13645341
Oh it's terrible, considering there are FAR better models for the same price
https://linustechtips.com/topic/1200116-cooler-master-psus/#findComment-13645414
