R5 3600 Temps
Go to solution Solved by jtmoseley,
3 minutes ago, fastfishy2 said:
Hi,
Running the above CPU stock with a Cooler Master Hyper 212 Black Edition that also has two Noctua NF-P12 1300 PWM Fans mounted in push-pull config. With a fairly aggressive fan curve and an ambient temp of 22c I get upper mid 70c's during OCCT Medium Stress Test. Is this okay for this cooler and CPU? Case has good airflow and yes I did remember to take the baseplate sticker off before applying thermal paste (Noctua NT-H1
Thanks
Perfectly fine.
Don't worry about temps unless they get to 90+ degrees on spikes.
Hi,
Thanks
https://linustechtips.com/topic/1200077-r5-3600-temps/
It's a stress test. They're supposed to get hot.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/1200077-r5-3600-temps/#findComment-13644125
Hi,
Thanks
Perfectly fine.
Case: InWin 303 Motherboard: Asus TUF X570-Plus Processor: Ryzen R9-3900x GPU: Gigabyte RTX 3070 Ram: 32 GB DDR4 3000 MHZ
 PSU: Corsair CX750M Storage: 1TB Intel 660p NVME SSD and a 2TB Seagate 7200RPM HDD Mouse: Logitech G600 Keyboard: Razer Blackwidow Ultimate 2014 HeadphonesSteelseries Arctis 7 Audio: Shure PGA58 with a Focusrite Scarlett Solo 3rd Gen
https://linustechtips.com/topic/1200077-r5-3600-temps/#findComment-13644134
2 minutes ago, fastfishy2 said:
Hi,
Thanks
thats perfectly fine, r5 2600's and 3600's at 70-90c is normal (especially if you raised the voltage)
https://linustechtips.com/topic/1200077-r5-3600-temps/#findComment-13644137
Just now, fastfishy2 said:
thanks for that. Also why you gotta do my boy Elendil like that 😭
It wasn't personal.
Actually now that I think about it it was definitely personal.
sudo chmod -R 000 /*
https://linustechtips.com/topic/1200077-r5-3600-temps/#findComment-13644138
