I am wondering wheather anyone nos the performance difference between the
http://www.overclockers.co.uk/showproduct.php?prodid=WC-356-EKEK Water Blocks EK-Supremacy Clean CSQ - Acetal
and the
http://www.overclockers.co.uk/showproduct.php?prodid=WC-306-EK&groupid=962&catid=1519&subcat=2286 - EK-Supreme LTX CSQ Intel CPU Waterblock
as i have been told to go for the top one but dont see the point if the performance difference is only a couple of degrees.
https://linustechtips.com/topic/119966-water-cooling-blocks/
Finaly a non bios answer :D been asking on overclockers forum and all i ge5 on there is dnt go h220 go for custom loop and then when i asked what the difference in temp is between them block all i got was them explained what the name ment then them saying go for this block nothing sayin wst the temo difference would be
Thanx again for the reply i have been pricing up a watercooling system and have worked out by changing to the cpu block a different reservoir and tubing i have managed to knock about £40/60 off my setup which means i can afford to trest my self to a 780ti instesd of just the 780 lol
https://linustechtips.com/topic/119966-water-cooling-blocks/#findComment-1598219
I haven't seen reviews for either. I assume being an EK supreme they are both high restriction blocks requiring high flow rates to perform well but short of a proper review its hard to say. These days the difference from the best to the worst blocks seems to be about 5C so long as everything else is OK so it wont matter much. But I would try and hunt down some quality in depth reviews on them comparing to other blocks before purchasing.
https://linustechtips.com/topic/119966-water-cooling-blocks/#findComment-1599903
The supremacy is their high end CPU block, and has the most support for different socket chipsets (it comes with replaceable jet plates that work better for different sockets).
https://linustechtips.com/topic/119966-water-cooling-blocks/#findComment-1603024
