32GB (2x16GB) for a Ryzen 3600X
Solved by berberries,
The Trident Z NEO series is made for ryzen with better compatibility etc. But the normal ones work fine.
That being said, main difference is the 3200 and 3600MHz speed. Sure the 3600MHz will yield you maybe 1-2% performance increase from the 3200MHz, but whether its worth the $29 is up to you. Both will work just fine.
Featured Topics
Bonznumber1 ·
Posted in Windows0 -
aqarwaen29 ·
Posted in CPUs, Motherboards, and Memory4 -
17
5
IBM_THINKPAD_R51 ·
Posted in Servers, NAS, and Home Lab0 -
5
2
1
