I bake my old R7 265 and I listen some popcorn sound
I don't have anything to do so I try to bake my old Sapphire AMD R7 265 (GPU), (following linus tech tips videos) and after some seconds I heard popcorn sound.
As you can see in the picture, it seems that some capacitors explode.
my question are:
  1. It's worth tring to replace that capacitors? maybe I could buy it on aliexpress.
  2. Do I have to buy the exact condensator? or Can I replace with something similar (higher voltage but same microfarad?)
thank you in advance
PICS HERE
Oh in case you are wondering why the gpu stop working, I don't know, one day, some years ago, it stop working...fan works but no video.
3 minutes ago, RealPsygnosis said:
You don't need to link imgur, pictures can be added directly to LTT posts.
Primary PC:
