Dell Dimension 4300S and a Flex ATX Power Supply
NTDaws
Hey guys, I'm thinking about doing a Dell dimension 4300s sleeper. I'm curious if a Flex ATX power supply will fit in Dell's proprietary size. I may have to drill holes but I just need to know it'll fit under the graphics card.
The geek himself.
i mean usually with sleepers , you mod the inside of the case to fit everything and then the outside is left to look as identical or the same as it was before
so if you can i recommend just modding the case from the inside as all sleepers (at least the ones i saw )
Phone: Pixel 3a (Purple-ish).
Build Log:
I don't tend to care for the back IO that much.
The geek himself.
truth to be said i dont know a psu to fit in such a proprietary space so if you want to fit an atx psu in it i think modding is required but maybe as sfx psu could work
could you tell us the exact model of the 4300s because there are normal atx ones and there are odd sized ones
Build Log:
No, not ATX, Flex ATX.
The geek himself.
oh my bad didnt see that lmao
Build Log:
still from what i have seen since i am not familiar with the 4300s series
i saw multiple models of it
so which one is it ?
Build Log:
i saw multiple models of it imageproxy.php?img=&key=0c2a8b7d8afbc61a
Skinny one top left
The geek himself.
so im back
and this was harder than i thought
from what i have seen there is next to nothing about the exact model of this machine but i have found a bit about the 4500s which apparently can fit a normal sized atx psu but im not sure which model they are talking about
there is next to nothing about sleeper projects for this case (at least from what i have seen )
Build Log:
so im back
It's never been used for a sleeper before as far as I'm aware. That's what makes it unique.
The geek himself.
