None, that's an ATX board
No mATX case will fit a form factor bigger than what it was made for
https://linustechtips.com/topic/1197640-will-it-fit/#findComment-13625835
1 minute ago, Goku1814 said:
pc part picker lied to me then lol
how about you share a parts list so we can corroborate
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1197640-will-it-fit/#findComment-13625842
Just now, Goku1814 said:
i already have everything else but the pc case
when choosing a case with PCPartPicker's filter for micro ATX mid towers and mini towers, only cases that are not available on the market are showing up, and many are clearly mislabeled as micro ATX cases when they are ATX cases. Definitely just a small discrepancy on the part of these classifications.
They do make a B450M Gaming Plus, if that suits your fancy, but you'll probably have to find it on eBay.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1197640-will-it-fit/#findComment-13625855
all i need is a cheap asf atx pc case i dont care if it has usb 3 or anthing fancy.
https://linustechtips.com/topic/1197640-will-it-fit/#findComment-13625858
you won't really be able to find a modern case without USB 3.0
Here's a cheap but good case
https://pcpartpicker.com/product/vYp323/cougar-mx330-atx-mid-tower-case-mx330
Lots of space, I've done several builds with it and it is really nice to build in. I recommend a fan or two since it only comes with one. LED fans look pretty great under the front mesh so some red glow is a welcome addition.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1197640-will-it-fit/#findComment-13625868
thxs
https://linustechtips.com/topic/1197640-will-it-fit/#findComment-13625870
I would spend the few extra bucks for the tempered glass version if you want it. @Goku1814 Also that case you originally linked would fit that motherboard.
https://pcpartpicker.com/product/zhjJ7P/cougar-mx330-g-atx-mid-tower-case-mx330-g
https://linustechtips.com/topic/1197640-will-it-fit/#findComment-13625891
Out of stock so I suggested the non glass one
Also, one of the advantages of this case is that it's very light, adding a glass panel would be quite heavy.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1197640-will-it-fit/#findComment-13626044
