Building a pc
By
Guest
in New Builds and Planning
Solved by MartinKweh,
It would be fine. Though i would suggest stepping up to atleast the 2200g or even the 3200g for the additional cores since it helps a bit.
You could also just ge the ryzen 3 3100 and get a used rx 470 or 570 since those wont go passed your budget. If i remember right , you can get the rx570 below $80 now.
derekchan ·
Posted in New Builds and Planning4 -
5
1
5
kerriya ·
Posted in Cases and Mods9 -
octester ·
Posted in Troubleshooting7 -
DavidPatrascu ·
Posted in General Discussion9
play_circle_filled
Latest From ShortCircuit:
