Using a mobile as a webcam and audio input for zoom
Joshp
Hi all,
Could anyone recommend an app for my phone and pc that can utilise my phones cam and mic that can be trusted?
Thanks,
Josh
7 minutes ago, Joshp said:
Hi all,
Thanks,
Josh
There are multiple tutorials out there which explain this better than I do but the general idea is that you download an IP webcam app on your phone and you essentially host a camera live feed online which you can use on your pc, however I'm not sure you can use your microphone as well. I'll leave a couple of guides here that should hopefully help you.
https://www.tomsguide.com/uk/news/how-to-use-your-phone-as-a-webcam
https://www.digitalcitizen.life/turn-android-smartphone-webcam-windows
https://www.skipser.com/p/2/p/android-as-webcam.html
You can use WoMic client for windows to use your phone as a mic , works on both iOS and Android
https://wolicheng.com/womic/
