Easy and simple solution: use in-ears and inline etc. mic for skype on one pc and headphones over them with another. Or just use skype on same machine?
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/119649-2-pc-audio-inputoutput/#findComment-1598823
Maybe a Y-cable, the one where 1 female (input) is split to 2 males (output). Y cables are usually quite short. You can build one yourself though. Just need the plugs, wires, and some soldering skill
https://linustechtips.com/topic/119649-2-pc-audio-inputoutput/#findComment-1598861
  • 2 years later...
