hi everyone!
i got a 3700X and i think my stock cooler isn't doing a good job. it feels like its throwing the heat to the case (Fractal Design Meshify C) space and making it even more difficult i have a GTX 1070TI that's generating tons of heat on its own. i have 2 intakes on the top, 2 intakes in the front, an exhaust at the rear and another exhaust on the bottom front fan mount. i have a feeling I'm doing something wrong here with the cooling and because of that i get stutters and frame drops
do you have any suggestions? things i should buy? things i should reconfigure?
https://linustechtips.com/topic/1196354-cooling/
2 minutes ago, Soldier_boy said:
hi everyone!
What amount of money are you willing to spend on a cooler?
What would you prefer an aio or an air cooler ?
But most importantly budget?
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1196354-cooling/#findComment-13616081
Before buying a new CPU cooler I'd first try setting up my fans in a way that actually makes sense. Set your front and bottom fans as intakes, and rear and top fans as exhausts.
The stock cooler should be fine for stock speeds. What temperatures are you hitting on your CPU that it makes you think that that's what's causing stuttering/frame drops in games (check with Ryzen Master or HWiNFO)?
Also, please don't make three separate posts for the same thing. We'll see it even if you post it once in a single section of the forum.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1196354-cooling/#findComment-13616084
-Merged-
You only need to post once
https://linustechtips.com/topic/1196354-cooling/#findComment-13616087
11 minutes ago, Soldier_boy said:
hi everyone!
Change the top 2 to exhaust and the bottom to intake
What ram do you have and what is the configuration
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
https://linustechtips.com/topic/1196354-cooling/#findComment-13616116
id say around 300$ although it feels a lot for a cooler. i have corsair products so would be nice to have corsair but not a must. and i don't mind air or AIO cooler but if there is a budget option for a good AIO that would be nice, thinking AIO's are generally better than air coolers
https://linustechtips.com/topic/1196354-cooling/#findComment-13616328
fix your case flow first.
heat rises btw
https://linustechtips.com/topic/1196354-cooling/#findComment-13616333
i can set it that way but im afraid the top exhaust will take fresh air from the CPU from the top front fan. what do you think?
im getting 63.3 on my CPU and 57 on gpu (both are from the max column on HWinfo)
https://linustechtips.com/topic/1196354-cooling/#findComment-13616348
I didn't read the airflow part of your post but now that I have I agree with @Mister Woof said
First improve airflow and then the cooler
Build Log:
https://linustechtips.com/topic/1196354-cooling/#findComment-13616350
No it won't do that
If there is intake inthe front the cpu will get the fresh air from there (typically the best config )
Build Log:
https://linustechtips.com/topic/1196354-cooling/#findComment-13616352
2X16GB sticks of vengeance pro rgb 3000mhz
elaborate on stutters and frame drops.
what games
what settings
what situations
https://linustechtips.com/topic/1196354-cooling/#findComment-13616363
  • 2 weeks later...
hey guys, coming back to you with results (took way to long then it should, personal life issues)
after configurating my fans to 3 intakes at the front and 3 exhaust (2 top and 1 rear) the system feels a lot better.
using HWiNFO64 im getting 459 C on CPU Die on average and 55C on the GPU (after using spotify for a couple of hours (and watching an LTT video haha)
after playing for an hour (apex legends) im getting 50.5 on CPU and 59 on GPU
it feels a ton better and i have to thank you guys for the help, tho im still having stuttering and frame drops... any suggestions?
https://linustechtips.com/topic/1196354-cooling/#findComment-13664048
1 minute ago, Soldier_boy said:
459 C
I'm gonna assume you mean 59c 🤣
Build Log:
https://linustechtips.com/topic/1196354-cooling/#findComment-13664056
can you report what windows resource manager says for your memory usage?
task manager -> performance -> memory
specifically under hardware reserved section
memory.thumb.png.445505cf68bd9671745a3131b612f62d.png tab
https://linustechtips.com/topic/1196354-cooling/#findComment-13664138
And do you have xmp/dcop on ?
Build Log:
https://linustechtips.com/topic/1196354-cooling/#findComment-13664140
i do have dcop on. i also set it to asus optimal in the bios (seem'd like a good choice, i think it does something like an AI overclock or something lik e that)
https://linustechtips.com/topic/1196354-cooling/#findComment-13666880
52 minutes ago, Soldier_boy said:
so what do i do? @Mister Woof
I don't really know what's the next step.
Some user get hardware reserved ram problem but doesn't seem to be case.
What games, what resolution, and what do you mean by frame drops/stuttering?
https://linustechtips.com/topic/1196354-cooling/#findComment-13674375
i mainly play apex legends. i play on 1080p, not pushing the setting too much. and by frame drops/ stuttering i mean the game just suddenly gets stuck for a super short moment (feels like a frame) and i look at the frame counter and see that i dropped from 144 to 30 and its rising back up. sometimes its server issues (i can tell by the weird server signs appearing in the right corner of the screen) but usually it looks like its my PCs problem. is there any chance that the problem is the HDD? i have a 7200rpm toshiba one that is about 5 y.o
https://linustechtips.com/topic/1196354-cooling/#findComment-13677909
