Question about rails
Go to solution Solved by Juular,
@IAmAndre As you can see, Corsair HX1000i has 8 12V rails, don't remember exactly but out of those, 6-7 are used by GPU connectors probably, whereas your PSU only has one rail for GPU connectors.
Hi,
I have a Be quiet! Pure Power 11 400W and it struggles to power my system properly although it shouldn't. I have a Ryzen 5 2600X and a Vega 56, which I undervolted/overclocked and currently peaks at 175W in benchmarks. I've seen on YouTube/Google people having this issue and it seems to be fixed by using a second power cable, the problem being that the rail is saturated. However I don't understand how this works.
These are the specs of the PSU: +3.3V@24A, +5V@15A, +12V1@24A, +12V2@20A, -12V@0.3A, +5VSB@3A.
From what I understand, the CPU and GPU all use the 12V rail, which would mean that their total consumption shouldn't exceed 288W. However, since there are two 12V rails, why can't I just have the PSU use a different rail without having to buy a second PCI cable?
Thanks,
https://linustechtips.com/topic/1196231-question-about-rails/
You forgot to describe in what way does it struggle to power your system properly.
The CPU 4+4pin cable uses the 12V2 rail, while the 24pin cable, PCIe cables and peripheral cables all use the 12V1 rail.
3 minutes ago, Matty2048 said:
use hwinfo to see whats happening to your rails e.g. are they being pulled down too much
Software voltage readings are useless because they're never accurate.
https://linustechtips.com/topic/1196231-question-about-rails/#findComment-13615214
According to manual, on 400W version PCIe cables are powered only by 12V rail #1, rail #2 is only powering CPU 4+4 pin cable. And even though 288W (minus some 30-50W for CPU and drives and plus some headroom due to OCP usually being higher than claimed) on 12V rail #1 is technically enough for any GPU out there, AMD Vega has very high transient load spikes which triggers OCP on rail #1. You need to change the PSU or GPU.
Tag or quote me so i see your reply
https://linustechtips.com/topic/1196231-question-about-rails/#findComment-13615219
It basically restarts when I run pretty much any game at a resolution higher than 1080p. Well I've only tried demanding games so far such as Rise of the Tomb Raider, Jedi Fallen Order etc. GTA V worked fine though. I even got a restart after I switch from 4k to 1440p on Tomb Raider.
https://linustechtips.com/topic/1196231-question-about-rails/#findComment-13615230
9 minutes ago, Juular said:
According to manual, on 400W version PCIe cables are powered only by 12V rail #1, rail #2 is only powering CPU 4+4 pin cable. And even though 288W on 12V rail #1 is technically enough for any GPU out there, AMD Vega has very high transient load spikes which triggers OCP on rail #1 (probably around 30A). You need to change the PSU or GPU.
Any idea why using two separate PCIe cables helped some?
https://linustechtips.com/topic/1196231-question-about-rails/#findComment-13615242
Hmm, the only thing that comes to mind is voltage drop but that shouldn't be an issue here. Regardless, powering AMD Vega with this PSU were a bad idea to start with, AMD Vega is a very tricky GPU.
https://linustechtips.com/topic/1196231-question-about-rails/#findComment-13615252
If the CPU is powered by the rail one, wouldn't that mean that rail 2 is dedicated to the PCIe parts, which would mean 288W for the GPU and the drives?
https://linustechtips.com/topic/1196231-question-about-rails/#findComment-13615304
Read again, or refer to actual manual. On 400W version of Pure Power 10/11, 12V rail #1 powers motherboard 24-pin, SATA and PCI-e cables, rail #2 powers only CPU 4+4 EPS connector.
https://linustechtips.com/topic/1196231-question-about-rails/#findComment-13615307
Well I'll see what happens with a new cable.
https://linustechtips.com/topic/1196231-question-about-rails/#findComment-13615681
Does this confirm my theory?
Here are the specs of the HX1000i according to Newegg:
 Single +12V Rail Mode: +3.3V@25A, +5V@25A, +12V@83.3A, -12V@0.8A, +5VSB@3A Multiple +12V Rail Mode: +3.3V@25A, +5V@25A, +12V1@40A, +12V2@40A, +12V3@40A, +12V4@40A, +12V5@40A, +12V6@40A, +12V7@40A, +12V8@40A, -12V0.8A, +5VSB@3A
https://linustechtips.com/topic/1196231-question-about-rails/#findComment-13615968
