Help with parts please -Custom Control pannel for Raspberry Pi
Solved by artuc,
You could ask to buy a higher quantity or ask for details on a distributor or supplier.
There are also panel mount industrial series that are similar, however they typically have the front cap tinted with a white light source.
Omron A16 and Schneider XB6 have square illuminated, however they are very expensive and can be hard to get in more obscure configurations. There are though more affordable ones from cheaper manufacturers. keep in mind these are often intended to be highly reliable industrial switches so are priced accordingly if not a cheap alternative.
Another option could be arcade switches.
