So lately my games keeps freezing and freezing. I enabled XMP and I got my 3600mhz speed and that's where the problem occurs. I put it on 2133mhz and 3200mhz and it seems like its stable.
My ram is G.Skill Trident Z 16GB (2x8) DDR4 3600MHZ. Is there anyway to set it to 3600mhz?
MOBO: MSI MPG X570 AM4
PROCESSOR: R7 3700X
GRAPHICS CARD: MSI RTX 2080 SUPER TRIO
RAM: G.Skill Trident Z 16GB (2x8) DDR4 3600MHZ
PSU: SEASONIC FOCUS 750W GOLD MODULAR
COOLER: Be Quiet! Dark Rock Pro 4
Twitchhttps://www.twitch.tv/b4mboozl3d Steamhttps://steamcommunity.com/id/asdjkasl/ YouTubehttps://www.youtube.com/channel/UCTjOU0RQuC5DQIx6mk3SLSw
PC: Motherboard - MSI MPG X570 Gaming Plus | CPU: AMD Ryzen 7 3700X | GPU: MSI RTX 2080 Super Trio | RAM: G.Skill Trident Z RGB 16GB (2x8)
PSU: Seasonic Focus 750W Gold Modular | Cooler: be Quiet! Dark Rock Pro 4 | Storage: Adata XPG SX6000 1TB m.2 | Case: FSP CMT340
https://linustechtips.com/topic/1194777-ram-problem/
PROCESSOR: R7 3700X
When you enable dcop / xmp you should get to the advertised speed
If that didn't work update your chipset firmware and update your bios and that should fix it
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1194777-ram-problem/#findComment-13604060
I tried enabling XMP and it also gives me crashes randomly.
I have also updated my bios, how do i update my chipset firmware? 😮
https://linustechtips.com/topic/1194777-ram-problem/#findComment-13604062
Through amd's site
And one more thing
Do you have your ram in slot 2 and 4 stupid question I know lol
And try maybe using 1 stick at a time
Before updating the chipset firmware / drivers
And try maybe setting your soc voltage to 1.1 and see if that helps
Build Log:
https://linustechtips.com/topic/1194777-ram-problem/#findComment-13604063
3 minutes ago, TofuHaroto said:
Through amd's site
And one more thing
i'll try to update it now. and yes its in slot 2 and 4.
im afraid to mess with the voltage tho. SOC voltage not dram voltage right? (Im new to this lol sorry)
https://linustechtips.com/topic/1194777-ram-problem/#findComment-13604078
Yes soc voltage
And one more thing maybe try manually ocing
Build Log:
https://linustechtips.com/topic/1194777-ram-problem/#findComment-13604088
6 minutes ago, TofuHaroto said:
Yes soc voltage
I also tried that by disabling XMP then setting my dram freq to 3600mhz (but i did not mess with the other settings, after i set my freq i saved it and reboot) and it still crashes my games. btw, enable XMP > then set soc voltage?
https://linustechtips.com/topic/1194777-ram-problem/#findComment-13604108
I recommend  setting the soc voltage just a tad higher and then enabling xmp
If that didn't work and you updated everything I'm out of ideas
Build Log:
https://linustechtips.com/topic/1194777-ram-problem/#findComment-13604116
seems like updating the chipset solved the problem (without touching soc yet) LOL. i'll try to update you when my game crashes again. THANKS MAN!!
https://linustechtips.com/topic/1194777-ram-problem/#findComment-13604194
Any time :D
Build Log:
https://linustechtips.com/topic/1194777-ram-problem/#findComment-13604215
2 hours ago, TofuHaroto said:
Any time :D
Nvm games are crashing again :/
https://linustechtips.com/topic/1194777-ram-problem/#findComment-13604484
Can you try 1 stick at a time and see if it crashes or not
Build Log:
https://linustechtips.com/topic/1194777-ram-problem/#findComment-13604518
Tried removing it but the lock is too tight. I can't remove it since the cooler is too big lol. Now I tried enabling XMP and set my soc to 1.1v
https://linustechtips.com/topic/1194777-ram-problem/#findComment-13604592
I'm gonna assume this didn't work lol
Build Log:
https://linustechtips.com/topic/1194777-ram-problem/#findComment-13604602
Haven't played any game yet hahaha. Do you think I should run memtest?
https://linustechtips.com/topic/1194777-ram-problem/#findComment-13604633
Yes run memtest for a while just to make sure that the dimms are working fine and as expected (crossing out fingers lmao )
Build Log:
https://linustechtips.com/topic/1194777-ram-problem/#findComment-13604679
No problems at all.
To solve my issue, I downgraded to 3400mhz, u think its fine?
https://linustechtips.com/topic/1194777-ram-problem/#findComment-13605652
On 5/15/2020 at 2:16 PM, Zektbach said:
No problems at all.
I would almost contact G.Skill to see what they say. Something is clearly wrong.
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1194777-ram-problem/#findComment-13609084
This is very unlikely considering zen 2 has a way better interconnect and a better imc but it could be that the OP lost the silicon lottery but as I said it's very unlikely
Build Log:
https://linustechtips.com/topic/1194777-ram-problem/#findComment-13609093
I tried AMD Dram Calculator + Thaiphoon Burner awhile ago, when I set all the timings recommended by the calculator after I boot up it says memory overclocking failure.
I wanna try it again but I'm kind of afraid to destroy my ram.
https://linustechtips.com/topic/1194777-ram-problem/#findComment-13609109
What cas latency do you have and what cas latency did the dram originally have
Build Log:
https://linustechtips.com/topic/1194777-ram-problem/#findComment-13609115
It's most likely not enough DRAM voltage.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
https://linustechtips.com/topic/1194777-ram-problem/#findComment-13609123
If you buy 3600Mhz ram, it should run at 3600Mhz.
Gaming Build:
Peripherals:
Laptop:
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1194777-ram-problem/#findComment-13609136
Uhhh I'm not sure, If you don't mind can you guys please check this out :/
https://linustechtips.com/topic/1194777-ram-problem/#findComment-13609142
Yes I know lol
But maybe by the slim ( very very slim ) chance that the memory controller can't handle it because it has bad silicon
But you must be stupid unlucky do have such bad memory controller
Build Log:
https://linustechtips.com/topic/1194777-ram-problem/#findComment-13609152
