So my Pc gives off an electrical shock when plugged in anywhere in the basement ( where I live ) And it travels into my keyboard my monitors and clearly my case I thought it was the power supply so I got a new one but it isn’t yet nothing else that’s plugged in down here has the same problem even my girlfriends computer is fine I took out my old PSU and it still was shocking me I don’t know it it’s the outlets which I doubt Bc everything else is fine or if it’s something else wrong in my case
and help would be appreciated
https://linustechtips.com/topic/1194769-system-shock/
Actually the PC which I used in my school 😂 also gave a shock when I touched the USB/Ethernet ports, I actually changed my socket as the original one broke, since then I never got that problem I don't know why, do it might be the outlet (but in my case the shock didn't went to my keyboard and monitor) so try using another outlet
https://linustechtips.com/topic/1194769-system-shock/#findComment-13604007
I've seen faulty power strips having some voltage on the grounding pins. And I've seen cheap sockets, new, having about the same issue.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1194769-system-shock/#findComment-13604028
This is the io shield not grounding properly
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 auros pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
https://linustechtips.com/topic/1194769-system-shock/#findComment-13604053
That's fucking wack, and makes alot of sense though.
Wouldn't that cause alot of problems though?
AMD blackout rig
https://linustechtips.com/topic/1194769-system-shock/#findComment-13604141
Depends on the device. In most cases people only notice the shock when they touch the device. I've seen this even with a laptop.
https://linustechtips.com/topic/1194769-system-shock/#findComment-13604152
As mentioned above, this could be the wall socket that isn't grounded, if not, it's either the power cord or the power strip.
To verify it, simply move your PC to the same outlet as your GF PC and see if the issue is still there.
If you need help with your forum account, please use the Forum Support form !
https://linustechtips.com/topic/1194769-system-shock/#findComment-13604668
The title made me think this was about the 1994 pc game that revolutionised gaming.
Regarding your pc shocking you in the basement, can you confirm that it only happens in the basement? or elsewhere also?
You say your girlfriends PC doesnt do this, are you testing it in the exact same outlet using the same power lead to test it?
It sounds like a grounding issue to me, a plug in GFCI would be an easy test.
https://linustechtips.com/topic/1194769-system-shock/#findComment-13604687
