Hey Guys,
So I recently bought a Zotac Mini GTX 1070 USED LIKE NEW. I installed it and everything was great. After a few days, i started to get lag spicks in games. So I decided to run user benchmark test. I closed everything, and my GPU was 15th percentile. Can you guys either help me find the issue, or help me decide whether return it or not. Returns expire in 2 days. Also my CPU is a Ryzen 5 1500x, and I bought the gpu on Amazon from a trusted seller.  Thanks!
https://linustechtips.com/topic/1194347-need-help-quick/
2 minutes ago, gtxboi17 said:
Hey Guys,
temps
ddu ?
whats your specs please ?
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1194347-need-help-quick/#findComment-13600954
3 minutes ago, TofuHaroto said:
temps
ddu ?
this please
Build Log:
https://linustechtips.com/topic/1194347-need-help-quick/#findComment-13600975
Just now, boggy77 said:
do you ahve 2 sticks of ram? are they in slots 2 and 4 and is xmp enabled?
this  completely went over my head
yes this too
Build Log:
https://linustechtips.com/topic/1194347-need-help-quick/#findComment-13600979
Just now, gtxboi17 said:
Ok will do! Ill get back to you soon!
good luck
but quick tip quote people so they can see that you replied
Build Log:
https://linustechtips.com/topic/1194347-need-help-quick/#findComment-13600981
what whats xmp
it over clocks your ram so it can run at its advertised speed (its called dcop for amd users )
Build Log:
https://linustechtips.com/topic/1194347-need-help-quick/#findComment-13600984
where would one enable that?
In bios of course
depends on your uefi every uefi is different
Build Log:
https://linustechtips.com/topic/1194347-need-help-quick/#findComment-13601000
you are not running xmp/ dcop enable  it
Build Log:
https://linustechtips.com/topic/1194347-need-help-quick/#findComment-13601005
ok! will that imprve my gpu score?
most likely will help your cpu and then gpu
Build Log:
https://linustechtips.com/topic/1194347-need-help-quick/#findComment-13601015
Ok. Should I do any other tests?
for now no just enable dcop
Build Log:
https://linustechtips.com/topic/1194347-need-help-quick/#findComment-13601036
