Just now, gtxboi17 said:
suggetions?
furmark
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1194347-need-help-quick/page/2/#findComment-13601045
I will, But just one question. I've always stayed away from over clocking because it harms the products. So will this harm the ram?
ocing doesnt hard the product lol
no it wont
Build Log:
https://linustechtips.com/topic/1194347-need-help-quick/page/2/#findComment-13601052
1 minute ago, gtxboi17 said:
maybe not harm, but ive had issues with overclocking crashes
that is expected if you push the hardware if it doesnt deliver   X power stably
Build Log:
https://linustechtips.com/topic/1194347-need-help-quick/page/2/#findComment-13601069
so your saying by enabling xmp there might be a risk of crashes?
nope xmp is a whole different thing than ocing the gpu or the cpu
Build Log:
https://linustechtips.com/topic/1194347-need-help-quick/page/2/#findComment-13601085
ok thanks
anytime :D
Build Log:
https://linustechtips.com/topic/1194347-need-help-quick/page/2/#findComment-13601094
havent done the xmp yet will do that. But you guys really think this will improve gpu proformnce from 15th?
as @boggy77 said it will improve the over all performance which will result in better gpu performance as a whole
Build Log:
https://linustechtips.com/topic/1194347-need-help-quick/page/2/#findComment-13601124
does everything look good here?
from what i can see looks like you have done 0 TOTALLY NO over clocking eh ? lmao
Build Log:
https://linustechtips.com/topic/1194347-need-help-quick/page/2/#findComment-13601134
yes cause i dont want My MINI card to over heat
So after multiple times saying you would do the benchmarks suggested to you multiple times will you finally do them or not? :P I am asking because you said yourself you are in a hurry.. so by not presenting us the results you only lose time..
https://linustechtips.com/topic/1194347-need-help-quick/page/2/#findComment-13601142
what do you suggest to but it at
not necessarily since these mini cards have less power phases and are usually not made for ocing
Build Log:
https://linustechtips.com/topic/1194347-need-help-quick/page/2/#findComment-13601146
oh yes my bad ill ss
https://linustechtips.com/topic/1194347-need-help-quick/page/2/#findComment-13601149
so your saying dont oc?
not advised with these cards so no
Build Log:
https://linustechtips.com/topic/1194347-need-help-quick/page/2/#findComment-13601155
20 minutes ago, gtxboi17 said:
could i push gpu clock to 2000MHz or not advised?
That yes you can probably do
Build Log:
https://linustechtips.com/topic/1194347-need-help-quick/page/2/#findComment-13601243
hey i checked and my ram is in a2, and b2. on a killer x370. would that be correct?
yes that is correct. also your gpu results in userbenchamrk is in the 15th percentile probably because it's a mini card. so it's probably fine, it just won't boost so high as a full card.
https://linustechtips.com/topic/1194347-need-help-quick/page/2/#findComment-13601350
Ok, so i enabled, xmp in bios. i set it 2666 mhz, but on the box of the ram it stated 2400 mhz. What do you think I should set the mhz to. Thanks. PS. my ram is:Evo Potenza
https://linustechtips.com/topic/1194347-need-help-quick/page/2/#findComment-13601384
