10 minutes ago, gtxboi17 said:
Ok, so i enabled, xmp in bios. i set it 2666 mhz, but on the box of the ram it stated 2400 mhz. What do you think I should set the mhz to. Thanks. PS. my ram is:Evo Potenza
Well your cpu is zen 1 and that is isn't known to have the best memory controller so you can have just lost the silicon lottery
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1194347-need-help-quick/page/3/#findComment-13601426
3 minutes ago, gtxboi17 said:
What? So I shouldn’t OC?
No I mean you won't be able to get as good of an oc on your ram
Don't be paranoid about these things lmao
Build Log:
https://linustechtips.com/topic/1194347-need-help-quick/page/3/#findComment-13601471
13 minutes ago, gtxboi17 said:
Should I keep it at 2666? Also yeah hahah
If this is the best that you got yea
Build Log:
https://linustechtips.com/topic/1194347-need-help-quick/page/3/#findComment-13601519
9 minutes ago, gtxboi17 said:
No In bios it is I CAn I go to 3300
What is your kit rated at ?
Build Log:
https://linustechtips.com/topic/1194347-need-help-quick/page/3/#findComment-13601612
Overall do you suggest keeping the gpu?
The GPU us for the most part fine
Build Log:
https://linustechtips.com/topic/1194347-need-help-quick/page/3/#findComment-13602243
1 minute ago, gtxboi17 said:
Even in the 13th percentile?
Just like what @boggy77 said this is a low powered 1070 so it will be clocked lower because of the lesser power phase design
But you can check a YouTube video and compare the results
Build Log:
https://linustechtips.com/topic/1194347-need-help-quick/page/3/#findComment-13602259
