ryzen High frequency low CPU usage Ryzen 3700X
Solved by boggy77,
it's normal. you're probably used to laptop cpus that go to lower frequencies to save battery.
Seosamh_101 ·
Posted in Windows1 -
1
1
2
3
ShayOh ·
Posted in Troubleshooting2
play_circle_filled
Latest From Linus Tech Tips:
I Will NOT Give You $250 for Your Broken Game - WAN Show April 26, 2024
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
