Nzxt H500i temps
Solved by LogicalDrm,
22 hours ago, HairyPotter said:3500-4000 rpm when in games according to hwd monitoring
Thats about 2000rpm more than what they are rated at. Either your software has some serious bugs, or you are looking at GPU fan speed. GPU temps are on the hotter side, but otherwise you have normal temps. Switching AIO to top exhaust and moving both exhaust fans as just front intakes would improve GPU temps. You can also try to tweak GPU fan curve to be bit more aggressive, but this will ofc mean more noise. The temps aren't dangerous, just bit hot.
