I have been having issues with the mic on my HyperX Alpha being rather quiet while using them with my computer (plugged into onboard from the back). I have spent the last 2 hours researching issues related to Windows, audio drivers ect... I have determined in short that the signal should be amplified before it gets to my computer in order to make myself heard and to avoid distortion that, as I understand, is created by digital amplification. Keep in mind I am not well versed in the world of audio equipment. Also I have no need to amplify the audio going towards my headset, all that is working fine, I'm only worried about the mic.
My questions are thus: what hardware do I need in order to do this and will this type of solution even work for this application?
https://linustechtips.com/topic/1193623-headset-mic-amplification-help-please/
Did you uise a 4 pole splitter?
What ports did you plug it into?
Did you check the manual to see if that controller thing on the cable affects the mic volume with any of its settings?
How are you actually determining that the mic volume is too low?
F@H
GPD Win 2
Discord's mic test. When I use manual voice activity the slider needs to be set to about -85db in order for it to trigger, and the audio quality is poorer than I would expect and I think that is due to the mic boost being set to +30db.
Those numbers sound fine, my detection is at -83 and I'm using a studio mic in a relatively high end setup.
There's nothing wrong with low audio levels in Audacity either, signal is very often boosted in post to reach usable levels.
Headset mics will never be the best sounding option but they're certainly one of the most attainable for gamers on a budget.
Sloth
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
