Ryzen 2600/X + 120mm cooler performance
Aniallation
Is anyone here running a 2600/2600X with say a Hyper 212/Gammaxx 400 and can chime in on your temps?
I recently upgraded from a 1200 to a 2600X and retained my Gammaxx GT RGB, which supposedly performs about the same if not slightly better than a 212 Evo, and applied new MX4. Idle sits around 38-40c and under p95 sits around 73c-75c. Are these normal temps for this setup? I don't remember what temperatures I got before with my 1200 @ 3.9GHz/1.4V when I ran the same tests, but I don't remember load temps being this high even though it was a lower power CPU.
"Rawr XD"
Those temps are perfectly normal.
I run similar temps on a 3800x on 240mm AIO.
The 2600x has a max safe temp of 95C, and idle doesn't really matter, it's load temps what counts. So I would say as long as your load is under 90C you're good to go.
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
I don't use a second gen CPU with a tower cooler but 75 degrees in prime 95 is a good temp in any case, well within safe and cool boundaries.
Primary PC:
