Hi, some need some folding help.  I'm, relatively new to this.
I'm running a GTX980ti classified in my first x16 motherbord slot. Should be running in x16 as GPU0. But is running in x8 according to GPUz. This is also running 2 1080p displays.
I have my old GTX960 SSC in my 5th PCIe motherboard slot. This should be running in x8 mode as GPU1.  But is running in x8 according to GPUz. I skipped slot 3 to give the 980ti some breathing room, it was getting toasty with them next to each other.
I have a MSI X99 SLI Krait Edition mortherboard, running a 5820k @4.5 ghz.
The 960 is taking 4-5 hours per work request which appears normal.
The 980ti was taking 2-3 hours per request which also appeared normal, and left the system usable for other tasks.
Not the 980ti is taking over a day to complete a request and leaves things unusable and glitchy for the most simple pc tasks. It's acting like its half the card the 960 is.
Any help would be appreciated.
https://linustechtips.com/topic/1191095-need-folding-help/
Have you done any troubleshooting so far such as removing the GPU slot and re-adding it on the F@H client? This could solve your issue.
https://linustechtips.com/topic/1191095-need-folding-help/#findComment-13576989
Found the issue.  Even though I was only using 2 GPUs, because of the slot the second one was in it was treating as a 3-way, not a 2-way which shut down my performance.
https://linustechtips.com/topic/1191095-need-folding-help/#findComment-13577365
