Is it possible to turn off RGB fan light?
Solved by Entropy.,
2 minutes ago, Enry said:Hello, I was looking to buy a Corsair Carbide spec-delta RGB case with MSI Tomahawk MAX motherboard.
I'd like to know wether it's possible to adjust rgb light brightness in the stock case fans setting the brightness to zero.
I'm asking because even though I appreciate the rgb light I'd like to be able to turn it off at night or maybe while I'm watching a movie.
Obviously. That would be a little dumb if that wasn't possible wouldn't it be? Usually you can use softaware to control it, and sometimes you can do it on the physical case, but usually software such as MSI mystic light and Corsair ICUE will be able to control RGB lighting- And turn it off if you desire
