Hello everyone,
I'm about to buy gskill 2400mhz 16gb ddr3 memory.
I own an Intel DH87RL motherboard.
Plz tell me will I be able to run the memory at full speed.
If yes , then how do I do that?
If no , then what's the Max. speed I can get, nd how to achieve that.
I tried finding XMP profile in the bios but here isn't an option for that.
Plzz help me.
Thanks in advance.🙃
https://linustechtips.com/topic/1190716-need-help-regarding-ddr3-memory-overclock/
https://ark.intel.com/content/www/us/en/ark/products/69044/intel-desktop-board-dh87rl.html
idk about that never used an intel board before...maybe you can't tune the memory?not sure...=x
  • CPU
    AMD Ryzen™ 7 5800X 4.7Ghz
  • Motherboard
    MSI MEG X570 ACE
  • RAM
    G.SKILL Trident Z Royal Series 32GB (2 x 16GB) F4-3200C16D-32GTRS
  • GPU
    GeForce RTX™ 3060 EAGLE OC 12G (rev. 2.0)
  • Case
    Cooler Master MASTERBOX MB520 ARGB + Cooler Master MasterFan MF120R ARGB
  • Storage
    ADATA XPG SX8100 2TB PCIe Gen3x4 M.2 2280 SSD
    ADATA LEGEND 960 4TB PCIe Gen4x4 M.2 2280 SSD
    ADATA Ultimate SU800 2TB 2.5" SSD
    Crucial BX500 2TB 3D NAND SATA 2.5-inch SSD
    Toshiba X300 4TB 7200 RPM
    TOSHIBA MG06 (MG06ACA10TE) 10TB 3.5 Inch 7200RPM Enterprise SATA Hard Drive
  • PSU
    Cooler Master MWE GOLD 750 FULL MODULAR
  • Display(s)
    Acer KG271B Gaming Monitor (HDR Ready 27" 1920X1080 240Hz)
    MSI PRO MP241
  • Cooling
    Cooler Master MASTERLIQUID ML240R RGB
  • Keyboard
    MSI Vigor GK80 RED GAMING KEYBOARD
  • Mouse
    Razer Naga Hex Wraith Red Edition Wired Laser Mouse
  • Operating System
    Windows 11 Home
  • Router
    tp-link EB810v BE22000 Tri-Band Wi-Fi 7 VoIP Router
    Asus ROG Rapture GT-AX 11000
  • Network Card
    tp-link Archer TBE550E BE9300 Wi-Fi 7 Bluetooth 5.4 PCIe Adapter
Looks like it.
13 minutes ago, Xeon e3-1246v3 said:
Hello everyone,
Plzz help me.
Thanks in advance.🙃
The motherboard only supports up to DDR3-1600.
Because it is not a Z-series board, you might not be able to run it at full DDR3-2400 speed.
Plus, it will also depend on the CPU you are using, too.
Both CPU and motherboard needs to be able to run at those higher frequencies.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
1 hour ago, -rascal- said:
Looks like it.
Can I manually overclock the Rams nd then be able to run it??
It will depend if:
  1. Your motherboard has support for manual overclocking, or options in the BIOS to run the RAM at higher frequencies
  2. If your CPU (you haven't mentioned yet) can support overclocking, or higher RAM frequency
If you run the RAM higher then what the CPU is rated for, you ARE overclocking the Integrated Memory Controller (IMC) within the CPU.
AMD Ryzen 9000 Rig
AMD Ryzen 5000 Rig
  • AMD R7-5800X
On 5/8/2020 at 2:09 AM, -rascal- said:
It will depend if:
I own a Xeon e3 1246v3.
Nd yes there is an multiplier in the BIOS which I can increase
