Changing thermal paste on intel stock cooler
Solved by LIGISTX,
8 hours ago, phil7990 said:My CPU is 5 years old almost and it never has been done before. Figured I might need to change it because people do it frequently... CPU's temps mostly 65-70 when stress tested...
There is no need to change it, it doesn't really go bad. It does technically go bad, but it will last WAY longer then you will own that PC for. There is no reason to change it frequently, actually some of them need a little time to "break in" before they work optimally.
Also, 65-70 in a stress test on a stock cooler is fantastic. Its really not worth the time, money, or wasting the paste.
