Hey everyone,
As you can see from the images bellow I have 7mm of clearance between the table top and the bottom of the case. What I would like to know is this enough room for the PSU - Silverstone ST45SF-G (It's a 450W power supply with an 80mm intake fan) to get enough air to, well... not blow up!...
Thanks in advance.
IMAG0189
IMAG0190
https://linustechtips.com/topic/119008-enough-airflow-for-psu/
Should be, if you don't out it on anything plush, like carpet or a rug.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/119008-enough-airflow-for-psu/#findComment-1586967
Is it possible to put it the other way in the case?
I destroy my enemies when I make them my friends.
~Abraham Lincoln
In times when we are on the brink of destruction, war, and loosing ourselves, let's remember a basic fundamental element of love, forgiveness, and understanding; God bless!
https://linustechtips.com/topic/119008-enough-airflow-for-psu/#findComment-1587009
Can we get some pics of what you want to do?
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/119008-enough-airflow-for-psu/#findComment-1587048
7mm should be fine, even 5 would be ok, you would just need to be on a flat surface. i would recommend over 1cm for carpet
My Car: http://linustechtips.com/main/topic/274320-the-long-awaited-car-thread/?p=4442206
CPU: i5 4590 |Motherboard: ASRock H97M PRO4|Memory: Corsair Vengance 8gbs|Storage: WD Caviar Blue 1TB|GPU: ZOTAC GTX 760 2gb|PSU: Thermaltech TR2 500W|Monitors: LG24M35 24" & Dual 19"|Mouse:Razer DeathAdder 2013 with SteelSeries Qck mini|Keyboard: Ducky DK2087 Zero MX Red|Headset: HyperX Cloud|Cooling: Corsair 120mm blue LED, Lepa vortex 120mm, stock 120mm|Case:Enermax Ostrog Blue Windowed
https://linustechtips.com/topic/119008-enough-airflow-for-psu/#findComment-1587435
It's fine man, don't worry about it.
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
https://linustechtips.com/topic/119008-enough-airflow-for-psu/#findComment-1587920
